TK35UE vs ld50
both have same batteries, both have same max lumen, both are simliar in price.
whats the pro/con of each one? i want to get a nice 1800 lumen light and dont know which one...
That's the 2200mah cells speaking I think.http://www.candlepowerforums.com/vb...8650-4xCR123A)-Review-BEAMSHOTS-RUNTIME-VIDEOthat's really crappy regulation plastic carrier, old design not much brighter than the much smaller Foursevens Maelstrom MMU-X3 not as bright as the Eagletac SX25L3 or Olight SR mini don't buy it
Regulation isn't that good indeed (when I see Selfbuilt's chart). That plastic carrier never failed on me, The switch (on my TK35 I had) did. Nothing wrong with re-using a good designhttp://www.candlepowerforums.com/vb...8650-4xCR123A)-Review-BEAMSHOTS-RUNTIME-VIDEO
don't buy it
don't buy it
don't buy it
It isn't all about brightness. Have compared the SR Mini against the TK35UE. Of course the TK35UE has better color rendering because of the NW led. Also it has more throw, then the SR Mini, if you need throw.
It's all about user preference.
Well you have to be fair. The SR Mini is a 3 18650 light and you have to hold down the button for burst. Don't know much about the SX25L3 so I can't say about that light.
I do think the LD50 has the potential to be a real killer of a light. Can't wait for the first good reviews.
He uses the 2200 mAh battery to test it.
Don't know what do you mean by "not as bright as the Eagletac SX25L3 or Olight SR mini"?
But neutral white led looks not as bright as cool white led at the same brightness level.
all these comparisons are taking into account different numbers of 18650 cells. But the 2x18650 Fenix TK35UE actually manages to do pretty well for the class, nearing the runtime performance of some of the larger lights.
ok...so i guess the choice is between sr mini, ld50, and eagle sx25L3...They all seem similarly priced at under $150...do they all take the same amount of cr123 batteries? are they all similar size and weight?
LOL it means TK35 puts out 2000 selfbuilt lumens. SX25L3 gets 2550. SR Mini gets 2800. get it?
the much smaller MMU-X3 gets 1700
of course when regulation is crappy you get long runtime albeit at low levels
2x 18650 is EXACTLY the reason why it sucks coz MT-G2 has high Vf. and the carrier design means that it's actually larger than the 3x 18650 SX25L3
Judging by the trace in sub's TK35UE review, turbo is regulated just fine until the battery voltage gets too low for the driver. That would be why 2200mah cells perform so poorly. I am guessing it would be better with cells that have flatter discharge curves like the LG D1 ICR's.3400mah cells will give pretty much the same curve, just on a longer time scale
Because LD50 can be runned with only one battery and one LED, the question is if each LED is powered by each cell undependently. If that's the case it means you don't need to use two matched cells, but you can run it with different mAh capacity if so needed. Or why not one 17670 and one 18650. Then it would be a pro for LD50: just mix any 3,7V cell with right length. Apart from that flat design may be an advantage.
Any information about that?
