ItzRav
I bought two of the new Cree 4Flow 60W-equivalent bulbs today, intending to use them in a totally enclosed ceiling fan light globe. Two similarly sized incandescent 60W bulbs had fit. But the two Cree bulbs were just slightly longer and thus too tight a fit. (These are A19 size; I had tried to find A15's in the 800 lumen range but couldn't find any.)
If I could remove just the top part of the cover, I think they would fit. Is it safe to run these bulbs with the cover removed, and will they run effectively? If so, what is the best way to remove the cover? I don't need to uncover the electronics in the base, and really only NEED to remove the top half or so. Since there are large air vents at the top, I figured it shouldn't make too much difference in how it runs. But if running them that way would be unsafe or mess up how the bulb performs, then I'll just have to use them elsewhere. Thanks.
