Hello,
I'm trying to plan out my first project using LED strip lighting, and I would really value the forum's input. I'm essentially trying to make a truck rack that has LED strips on the underside, so they'll illuminate the bed. The truck rack would be shaped like this, and I'm planning on making it (the rack, that is) out of steel tubing; the tubing on the rearmost crossbar and the bottom bars on the sides (from rear to cab) will be made out of slotted tubing, so as to protect the strips.
So the way I've figured it, I should be looking for an IP65 rated task-light with 300-450 lumens per foot, color temp around 5500K, as high a CRI as I can find, and preferably dimmable. That is from my limited experience and knowledge as a burgeoning flashaholic, so if I'm wrong, please tell me! I have found these strips and am specifically looking at the fifth one with the IP65 rating (SKU: IP65-UB-CRI-NW-12V), it seems to come closest of anything I can find to meeting what I think I need.
In addition to figuring out what strip I want to use, I've gotta figure out how I'm going to power it and control it: I think hooking it up to the battery would be easiest, and using one (or more) of these dimmer/controllers. Right now, I'm envisioning using one dimmer for all three sides, and running both sides in parallel (kinda like this picture). So, the way I see it, I'd run the supply wiring from the battery to the dimmer, which would be mounted in the center of the rear crossbar; from there, after the dimmer, there would be parallel wiring running from the dimmer to the left and right strips. I don't think I would need to use a driver (as my power supply would be 12v DC), although I don't know if it would be still recommended to use a driver to prevent current fluctuations. Also, seeing as how the manufacturer recommends a heat sink for the strips, would the metal tube itself work for that? (Plus it'll be used outdoors, which means there will be more airflow than cabinet lighting or some such, right?)
What do y'all think? I would really appreciate feedback. Thank you!
