I really just got into the charging game a month ago picking up a Nitecore D4 charger. However, I've wondered about solar solutions for charging my eneloops and Li-ions for my lights.
I've seen the foldable and portable solar panels with the USB connection going to the little AA chargers. But with no battery pack, no energy could be stored for night charging.
So my question is what is a straightforward and simple solution for getting set up to charge my batteries with solar? Is the USB the way to go but requiring buying 2 separate USB chargers for NiMh and Li-ions?
There's an adage with solar charging and much like 'fish tanks,' simply put, it's:
'Get the biggest you can afford, space/convenience allowing.'
Here's my 12v system that I put together 3 summers ago. It's not back-packable, but it's easy enough to manage:
http://www.candlepowerforums.com/vb/showthread.php?342073-Portable-solar-charging-setup-I-just-built
With any panel above 20w, it's suggested that you get a digital solar controller to regulate panel voltage, which can be up to 20+ volts.
Secondly, get a mother battery and stick that into the chain. You can charge that up by day and then charge your batteries/cells up by night. You can use the mother battery to run a 12v fan, if like me, you're in a hot place like Miami when the power goes out.
12v AGM/SLA mother batteries really aren't all that expensive and you'll get 3-5 years out of them, if you take care.
With a 12v system, I can run my Xtar VP2 and WP2 II chargers and my NiteCore i4 v2 charger.
After I put that system together, I decided on a 5v USB 'portable' system and bought a SunKingdom 14w USB folding panel and a couple of Xtar 5v USB chargers for li-ion (MP1+) and NiMH/li-ion (XP1.)
I also bought a Ruinovo 4x18650 power bank that came with 4 Sanyo UR18650FM 2600mAh 18650 cells. I can use the power bank, much like the 'mother batteries' and charge the bank up with the panel and then charge stuff up off of the Ruinovo and things are peachy.
The Ruinovo power bank has a 2A 5v input, so with the Sunkingdom 14w panel's two 2A+ outputs, I get a faster charge on the bank.
Small USB panels will charge small, so keep that in mind. A 12v system, one of 60w like mine, can deliver 3.5A and get those mother batteries charged up more quickly than smaller panels. My two mother batteries are 12Ah and 22Ah, so plenty of juice to take care of a bunch of Eneloops, li-ion cells and my fan.
I'm covered in any event--say if I have to bolt out the door to the beach, or out in the woods, or if my power has gone out in the event of a hurricane blowing through Miami, cutting power along the way.
Chris
