HKJ
[size=+3]Sony US18650V3 2250mAh (Green)[/size]
Official specifications:
A high current cell, but the specifications looks a bit dated.
The discharge curves look very good with both fine tracking and constant capacity at different load up to 10A.
[size=+3]Conclusion[/size]
Being a Sony it is a very good cell and a few years ago this would have been a well performing high current cell, but today there are many cells with better performance.
[size=+3]Notes and links[/size]
The batteries was supplied by Akkuteile.de for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
- Nominal Capacity: 2250mAh (0.2C discharge)
- Rated Capacity: 2150mAh (0.2C discharge)
- Capacity at 1C: 2137mAh (average capacity)
- Capacity at 10C: 2189mAh (average capacity)
- Nominal Voltage: 3.7V
- Cut-off voltage: 2.5V
- Internal Impedance: 31.5mOhm Typ. (measured by AC1kHz)
- Cycle Performance: 88% Min. of Initial capacity at 500 cycles(5A discharge)
- Charge Method: constant current constant voltage
- Charge Up Voltage: 4.2±0.05V
- Charge Current: 2.15A
- Charge Time: 2.5h
- Ambiance Temperature: 23°C
- Dimensions: 18.35mm(D)*65.10mm (H)
- Weight: Max.44g
- Continuous Max. Discharge Current: 10A
