ComputerTime
- Joined
- Jun 26, 2016
- Messages
- 24
Hi,
I am thinking of getting Xtar vc4 for the Lithium ion batteries because it can display the capacity of the charged battery. Do you think that this information is important or just a good to have inforamtion? From what I see on the operation of vc4, it seems that it is just a pulg-and-play device; you just put in a battery, it detects and start charging. Is this charger capable of doing discharge and charging, just like Maha C9000? I am not sure if Lithium ion need to be refreshed, like Ni-mh battery.
I am asking this because I savaged 6 18650 batteries from my old laptop battery, and all of them seems working fine, working voltage (when connected to a load) is around 3.6x. I like to know if the capacity has dropped due to ages. From what I know, Ni-mh battery will drop over the times, especially if they have not been used for quite some time. Will this happen to Lithium Battery?
Some other questions:
1) I saw that the Vc4 can revive dead battery, like to know how good is the dead battery capacity? back to the rated capacity?
2) I read of conversion rate of power bank, at around 80%, is is conversion rate mainly dependent on battery alone, or the circuit also plays an important role?
Regards.
Regards.
