Dear all,
I'm trying to find something similar to this one but with ore lumens and removable battery
*link removed
I search the forum but didn't manage to find any recent request for "Portable-Work-Light" (most answer were on Torch lamp)
I allready have two:
- 1st one doesn't provide enough light (600lm) but battery can be replaced (6x 18650 battery)
- second one is two time bigger, provide far more light (1600 lm) in a verywide beam, but battery can't be replaced and it needs to be reloaded before any use (even if i don't use it, battery will be empty within a week :thumbsdow)
so i'm trying to find a mix of these two one (battery replacement + lots of lumens)
I mainly use it to take video or photo of wide underground area (i have several other lamp for progression purpose or smaller area)
I put it in my backpack when not in use and attach it in front of me when I'm walking
Thanks in advance for any advice
Online
2) Budget:
Up to $100( 200 if very good quality).
3) Format:
____I want a Portable-Work-Light
4) Size: doesn't really matter till it fits in my backpack
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
____Bunch of 18650 (mainly to facilitate battery replacement) or at least a removable battery (so I could buy a 2nd one)
8) How much genuine out the front (OTF) light do you want/need?
____Maximum possible, at least 1600 lm as th eon I have already satisfy me
9) Flood vs Throw:
____All Flood: I'm lighting wide underground area, some of them may reach 20 meter high and hundred meter large or long
9a) Distance:
____150+ yards (I am searching from a helicopter)
10) Runtime:
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
11) Durability/Usage:
____A simple on-off with only one output level is fine for me.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
*link removed
Online
2) Budget:
3) Format:
9) Flood vs Throw:
9a) Distance:
10) Runtime:
____None needed
