MAD777
So, I removed my AWT IMR18650 3000mAh batteries from my Eagletac MX25L3 flashlight.
Upon loading them into my Liitokala 500 charger, I got the following voltage readings.
3.04
3.44
4.08
Wondering if my charger was giving me bad readings, I loaded them into my Gyrfalcon All-88 and got the same readings.
These batteries are about a year old and have been used occasionally for short periods of time. I regularly remove the batteries from all my flashlights about once every two months to recharge them, even if they haven't been used much. I've never seen this behavior in these batteries. I do have a few other of the exact same battery that have not exhibited any problems.
By the way, the batteries were all purchased as a set from a reputable dealer. Then labeled with the flashlight name and used only in that flashlight. They have been charged together, on the same charger ever since.
Should I toss these batteries? Can they be used in single cell lights with no worry?
(they are definitely not going back into a flashlight as a set).
Thanks for your advice!! :hairpull:
3.04
3.44
4.08
