[ QUOTE ]
Doug Owen said:
[ QUOTE ]
Ginseng said:
Gold Peak specifies a trickle rate of 0.05 to 0.1C for continuous trickle with their nimh cells.
[/ QUOTE ]
Indeed they do, but a couple of details need pointing out, first the standard for this continuous charge is "No conspicuous deformation and/or leakage", no word on what it does to service life.
And (under those conditions) there's a *manditory* voltage limit at 1.5 Volts (something I highly doubt is in the charger).
"Leave 'em in the charger until you need them" is a NiCd deal, not NiMH. If that's what you intend to do, best go that way. Hint, that's why 'modern' flashlights still use 'old fashioned' NiCds.....
Doug Owen
[/ QUOTE ]
Ok, we have these opinions, based on your experiences? Based on reading up on this topic? Based on reading of others experiences? If based on others experiences, can you provide links so we can read up on those?
A few points not mentioned here. Seems there is always some small risk of leaving these chargers unattended, what ever the type, NiCad, NiMH, and perhaps more risky(because of higher current capacities? or some other factor) the Li-ion/polymer formulations.
I see that while not conclusive, in the oft linked article below, the author likes to leave a set in the charger indefinitely for convinience sake.
The Ultimate battery (NiMH AA) shootout
But if you read the FAQ link/answers at Thomas Distributing, they offer a caveat about charging/recharging an already fully charged set of batteries. But they offer no supporting evidence/proof of what they claim to be a 'truth'?.
Who do we believe? Is this just another 'urban legend' of overly cautious battery manufacturers?
"and will PROBABLY cause damage to your batteries, charger or both."
And has Dave Etchells ever put a fully charged set of NiMh on the trickle charger by mistake, which may or may not be conclusive, to determine if this ever happens?
