[ QUOTE ]
What has been "proven" (and by the way, whats your source for this "proof"?) and what really happens in the field are often very different.
[/ QUOTE ]
There were tests on this done on bladeforums.com
[ QUOTE ]
I've used knives all my life, and ATS-34, 154-CM etc. have seen plenty of use from me, both in other knives and in knives I've made... I use a couple S30V blades as my EDC's, not because of the steel but because they are the designs I wanted, and while its good stuff, I wont disagree, I dont think it is three times better than ATS/154, better yes, but how much better? Not enough that I think it makes a difference as long as the design of the knife itself is sound, and its well made and heat-treated.
Being a steel snob was never my thing, I know good steel from bad, I know how to sharpen, I know how to treat a blade well, and I know what designs and shapes work best for what I want to do... all that evens it out, super steel or not.
[/ QUOTE ]
Look, ATS-34, or even a solid iron blade is going to get the job done. I've used ATS-34 for the last several years, it's not that it sucks, it's just that the newer steels are better.
I used an Athlon 2100 before buying my P4 3ghz, does that mean the Athlon sucks? No, it just means the P4 is better, and is an upgrade. The same is true for modern steels.
You can still use the Athlon as a computer, and you can still use the ATS-34 blade as a knife, and they'll probably do OK. But the Athlon isn't as fast, and the ATS-34 won't hold an edge as well as the S30Vs. Period.
[ QUOTE ]
Until that one night you need it desperately,
[/ QUOTE ]
You shouldn't be using a 3" pocketknife for self defense. According to the US army a knife must be 6" to be "minimally lethal" because you need a certain amount of penetration to reliably hit blood bearing organs and major veins/arteries. While you can kill someone with a 3" knife, it is a poor choice of a weapon. I'll stick to my Glock handgun /ubbthreads/images/graemlins/smile.gif
[ QUOTE ]
and your thumb shoots off the G-10 and right over or past that tiny little thumb-stud on the Avalanche, because A. its small and B. its barely taller than the G-10, which isnt re-cessed with a thumb guide for it, and instead of a knife all you have is a rather light-weight fistload.
Gimmie the hole anyday, I can open it just as fast and its a more reliable opener to find and stay on under stress. And I have owned both knives in question, and carried thumb-hole and assisted openers.
[/ QUOTE ]
Holes suck for that too dude. I won't say the thumbstud is any better or worse than the thumb hole on my AFCK. The best opener is the Emerson disk. You simply can't miss it, which I can't say for the thumb stud or hole.
[ QUOTE ]
For utility, for knifesturbation, for looking cool, assisteds are great... need one for more serious things, and they are, frankly, lacking and do not meet the standards of combative/life saving reliability. There are better ways.
[/ QUOTE ]
Assisted openers have proven to be reliable, so quite frankly your statement about reliability isn't true, and I challenge you to prove otherwise. They use a simple, reliable and effective mechanism. A high quality auto knife is also quite reliable and those have been around for a long time and proven themselves to be dependable.
[ QUOTE ]
Ok, I'm gonna say this as nicely as I can. You're smoking crack on the Axis Lock Vs. Liner Lock issue. The lockup with an Axis Lock is inherently stronger than a Liner Lock can ever be. Period. And only one spring is required to exert enough force on the locking bar to provide a secure lockup. Which means in order for the lock to fail, BOTH springs would have to break. That's simply not very likely. Where is a similar redundancy in the design of the Liner Lock?
Simple. It isn't there. The Liner Lock relies on friction to keep the locking bar in place. All it has to do to fail is slide off or as it has happened on some folders, the liner buckles.
[/ QUOTE ]
First of all, springs are inherantly weaker and thus more prone to failure than the liner lock. As far as the liner lock being weak... I challenge you to prove how many pounds of force it takes to subvert a liner lock. I don't see it happening, personally.
It's a big friggin piece of steel against the blade. That's pretty reliable, and strong. The AXIS lock is cooler, yes, but it has more moving parts, springs under tension, and more points of failure.
[ QUOTE ]
Calling the Axis Lock a gimmick is just pointless. The assisted opening is a gimmick, the same way automatic knives are gimmicks. Cool for the gadget factor only. They're not quicker to open than just about any other knife. I can open a knife like most any Axis lock knife, just as quickly as most people can locate the thumbstud on their assisted openers or the button on their automatic.
[/ QUOTE ]
The assisted opening is superior to a manual opening system in speed, period, and you can time it and quantify it. It's also a lot easier to open if you do not have the freedom of movement to "flick" the manual knife open. Further, flicking a manual knife open is not reliable as I have noticed the tension on the blade increases over time and I have to loosen it to reliably "flick" it.
Using the thumbstud or hole to open the blade without flicking it takes more force and more time than an assisted opener.
[ QUOTE ]
As for the steels, I never dismissed that the new "miracle" steels are better. There is no doubt that they are. I was merely dismissing your statement that all other steels are automatically crap. They're not. They've worked well for thousands of users for years and will continue to do so.
[/ QUOTE ]
Crap? No. But they're not as good. Bronze was used as a blade for thousands of years, and worked ok. It doesn't mean I'm going to get a bronze blade in my knife though, now does it? No. If I pay $100+ for a knife, I'm going to get the most up-to-date, functional tool I can.
[ QUOTE ]
Besides, it's kinda moot anyways, since more and more of the Benchmade's are S30V. Several new models have come out with that.
And then there's ofcourse their new model, coming out later this year, The Apparition that has an assisted opening system. It's a liner lock. I won't be buying it.
[/ QUOTE ]
And it's a good sign they're using more and more new materials, and I hope they expand this.
My dream knife is an 806 AFCK, made by Benchmade, with an assisted opening feature, S60V steel, and the Emerson wave opener and thumb-disk. Yes, the AXIS lock is part of it, because I do like the AXIS lock.
[ QUOTE ]
You oviously have not used a properly heat treated 1095 or D2 blade by a custom maker.
IMHO the maker controlling the heat treatment is more important than having the latest and greatest steels that happen to in the vogue at the moment.
I'll stick my neck out further. A D2 blade that's been heat treated (rockwell 59-61) by a master knife maker will out perform most any production knife using new steel of any flavor.
[/ QUOTE ]
The forging process and molecular structure is different in the S30V type steels and it is why they hold an edge better regardless of HRC (which is extremely close to Rockwell 59-61 anyway). They do not hold an edge better simply because they are "harder"; they hold an edge better because the structure is different.
BTW, I EDC'd a Benchmade mini-AFCK for ~7 years. Just so you know where I'm coming from. I currently EDC a Kershaw Avalanche, and my roommate EDCs an Emerson mini-Commander. At first I didn't want to even look at the Kershaw, because it wasn't a Benchmade.
