cypher2001
- Joined
- May 17, 2004
- Messages
- 48
I've been tasked by an associate to design or outsource a solution for a local religious establishment. I was hoping you guys might be able to point me in the right direction, or help me solve the problem.
Currently they have a large panels with plaques of deceased individuals. On specific days, they light individual lights on each side of the plaque.
System is setup as a common 110 busbar and neutral base and are running neon lamps.
I'd like to replace them with LEDs for the light source. (replacing the busbar with a common low voltage source)
The problem I have is that there are over 750 of these lights (Broken up into multiple panels, approx 200 each panel)and lighting them with a low voltage power supply.
Does anyone have a source for candleabra base LED lights (hopefully w/built in resistors) and any ideas on a power requirement for so many LED lights?
