Lunal_Tic said:I'm thinking about a mod to a 10W HID I've got that runs on 4xCR123s and I've read that 3xR123s work too. I've never used those but I've got a bunch of Pilas so I was thinking about a mod to the 10W HID using those. It would be similar to a Wolf-Eyes Dragon I methinks.
-LT
Re: AWR 'Hotdriver' hotwire LDO driver for Mag
Complete newb type question, could this work to limit the initial juice from 3 Pilas to the HID project over here?
-LT
ANSWER:
Lunal Tic.. brilliant.. yes it is a voltage limiter.. i believe if you are having over-voltage issues with the HID ballast mostly becaose of 'fresh cell' issues (i.e. if you want a nominal voltage of 10.8 but fresh cells of 12.6 are causing a problem).. this would work absolutely perfect in such a scenario.. i would add on a nice size capacitor on the output to reduce feedback ripples from the ballast causing a problem, but it should work well. -awr
