007 run 5 differences
bla2000
I've got the older 007. What are the differences between it and the newer one besides the led? I know about the following:
  • 1400 high
  • 4 memory slots
  • different method of programming levels
Can each level be set from 0.1 to 1400 or are there limits like on my older version?
Currently I have my levels set at:
  • 0.1
  • 5
  • 15
  • 50
  • 250
  • 1250
With the new version could I set?
  • 0.1
  • 0.5
  • 2
  • 13
  • 63
  • 312
  • 1400
  • 1400 high
  • 4 memory slots
  • 0.1
  • 5
  • 15
  • 50
  • 250
  • 1250
  • 0.1
  • 0.5
  • 2
  • 13
  • 63
  • 312
  • 1400
Sorry it took so long to answer, but better late than never. :)
There are no limits for each Position. So yes, you could set the six positions any way you want.
Cheers
Dave
That extra flexibility in setting the levels is nice. I never appreciated the value of a low low until setting my Spy. As you probably saw I incorrectly listed 7 settings. Also my Spy isn't set quite a low a 0.1. It's a few levels higher but even then it's still much lower than the low low on my Zebralight H31w.
I am thinking about getting one of these lights. Is the programming complicated? I have seen some directions here on programming, but does it come with a manual as well?
No, there won't be a manual. Just print off the directions from the other thread. Looking at the youtube video for the Tri-V programming should help as well (although there are some differences).
How about a post right here in this thread -- please -- on the steps necessary to raise or lower a given level in the new 007.
