100W Halogen bulb
blakegriffin
Where can I find a 100W Halogen bulb like the torch uses to build a flashlight with OR if any of you guys know any bulb more powerful That will still fit in a host. :devil:
Welcome to CPF, blakegriffin :)
I'll move your question to the Incan section, where you'll find plenty of information on bulbs.
"The Torch" uses the Osram 64623 bulb. If you search for this, you should be able to find it easily enough.
There are bulbs out there that are considerably more powerful - 400 watts for instance - but the real question is whether you can use them. The size of your light, and consequently the battery configuration that you are able to use, will dictate the power that is available to drive the bulb. When you are looking at 400w bulbs, you are looking at needing 36 volts.
Supplementary information
Since you need 36Volt, 10A+ is required and the power source is limited to Lead acid battery
Probably not a flashlight, a handheld spot light instead
why limited to lead acid???
imr, a123, lipo, nicd, nimh, all will give you 10+amps easy, with smaller size, a lot less weight
