from a german post:
http://forum.penum.de/showthread.php?id=24339
At power on the bc-900 (Firmware 33 and Board Rev. 06) indicate the temperature of the two sensors (for a moment)
The temperature is shown in decimal (RAW). The hundreds omitted. Supplements the hundreds arises the following table:
as a chart
The temperature was measured on the contact pins to the accu.
If I count the pins I see that the the BC-900 contains a 8-Bit micro-controller with 4x32 LCD-support, ADC with 10 or 12 Bit and Pulse Width Modulation (PWM) output. On the board a contacts for TX/RX
Which micro-controller is inside the BC-900??
Code:
Raw Temp[°C] Temp[°F]
231 9 48
183 14 57
142 18 64
131 20 68
110 25 77
81 30 86
71 35 95
64 37 99
60 39 102
56 40 104
54 42 108
47 45 113
43 48 118
36 52 126
-> Shut down at 53°C = 127°F= 35 RAW
