10440 recommendations for an Eiger?
manoloco
Lima, Perú
Which 10440 lithium rechargeable is recommended to run on an XP-G Eiger?, IMR are a bit harder to get for me outside USA, also dont know how the Eiger driver works, i imagine the IMR ones have less capacity than the AW unprotected ones; would the circuit take advantage of the IMR increased discharge capabilities and push more lumens out, or would an AW unprotected fare better because of more runtime?
that info would help me choose a rechargeable Li battery type and will also get eneloops for longer runtime needs.
thanks.
Thanks archimedes!, thats exactly what i was looking for, i will have to go the AW unprotected route (i do care for cells though so it shouldnt be a problem), i assume IMR would feed too much amperage to the led because of lower internal resistance.
Yes, I believe that is correct, as it would then push past the recommended operating specifications of the Eiger's Cree XP-G.
