I've resisted the Inova X5 for a long time.
Afterall it's a light based on five 5mm LEDs - and I already have the five 5mm LED Xnova 5 (version 1), and more recently the 8LED Xnova 8 new (brighter) version - I mean they have to be in a similar ballpark in performance, right?
Yes, I do realize the Inova X5 uses 2x CR123A lithium primary cells - that's a lot of power - capable of driving those really bright xenon incandescents like the SureFire 6P and the Streamlight Scorpion - so for five 5mm white LEDs?
To me that might not actually be such a good thing - unless this gives an astonishing long runtime - well Inova spec's the X5 at 20hours - good, but not too great.......
Inova X series are well built with type 3 hard anodizing -
but $35 for a five 5mm LED light?
Size comparison
first photo are lights compared in this review;
second photo is to give a little context with a well known light and a typical 2x CR123A xenon light......
Heads
The Inova X5 not only recesses the LEDs to both protect them and help prevent extraneous side-emissions** (see threads - Stray Side Emissions of Domed LEDs and Light Coverage - spill-diameter Pics)
- but the holes are formed so that they act like mini-reflectors to throw more light forward.
I'm starting to appreciate this X5 design/build more.
vs. Xnova 5 v1 (the original groupbuy from TrueBlue)
one can see the Inova X5 is much, much brighter with a larger/wider area of illumination.
So OK the Xnova 5 is an old one - version 1 - and the subsequent versions are brighter.
So compare the Inova X5 with the 8LED
Xnova 8 new/brighter version
Yes, the Inova X5 is still noticably brighter still with a much wider coverage.
This is more like it - with 2x CR123A lithiums (which are capable of driving xenon bulbs to spectacular brightness) I was hoping for more, and it seems to be meeting or even exceeding my expectations......
So how bright is this Inova X5 - on humble five 5mm white LEDs?
How about 1 watt Luxeon level?
vs. Fenix L1 v2.5 on fresh alkaline AA
very comparable - and indoors the Inova X5 seems to reach/throw as far as the Fenix..... and the tint of the X5 is actually pretty good - yes, as the -2 Stops underexposed shot shows there is a blue-ish center - but hey this is comparing with a Luxeon.........
Just to confirm this - compared to my favorite compact 1watt Luxeon
S1801 1watt 1xCR123A
Again this is very comparable -
Note: despite my digicam set to FIXED daylight white balance - I think the camera has done some white balance shifting - as I don't recall the S1801 (one of my favorite tints) being so "green" -
but again this shows the Inova X5's tint is actaully pretty good - for humble 5mm white LEDs.
I suspect from the tint and brightness characteristics and being a late model Inova X5 - it probably has Nichia CS LEDs.
OK, it might be debatable whether the Inova X5 is truly as bright as a 1watt Luxeon - since the beams of the lights compared are different enough in characteristics.
So how does the X5 compare to a good 1/2 watt?
vs. Nuwai TM-310H 0.5w 1AAA
The Inova X5 is definitely noticably brighter with a much wider hotspot coverage and much better tint (but then that's not saying much - since the Nuwai 1/2watts are notoriously blue - and this is my least blue one.........)
Lastly out of interest compared to its little brother -
vs. Inova X1 Spot white
pretty different characteristics - the X1 is a tight spot with no side-spill - the X5 is a wide floody-spot, and quite a bit brighter - so it is much more generally useful.
OK let's look at the design - and ** the recess for the LEDs -
this shows that the recess of the X5 is properly designed - so that there are no strong side-emissions - unlike the much cheaper Xnova 5 and Xnova 8 which show those characteristic strong side-spikes......
(note: the Xnova 8 appears less bright because of its wider flared head tilts the light upwards away from the paper - so it puts less light on the paper.)
Current draw - and runtime question -
set 1 - Duracell Ultra (supplied) 5.98V open-circuit = 0.26A
set 2 - Titanium 6.02-5.97V o-c = 0.21 to 0.23A
This means a total power draw by the X5 of between 1.35 to 1.55 watts.
Considering the nominal capacity of CR123A are 1500mAh (1.5Ah)
the claimed 20hours runtime seems "optimistic"
perhaps 6 to 7 hours might be closer?
Compare this with the S1801 1watt Luxeon running a single CR123A = 0.45A
its guesstimated runtime is closer to 2 to 2.5 hours
for a total power draw of 1.35watts......
I can see the popularity of the Inova X5 - it is very nicely put together - feels solid and quality - its performance is outstanding for just 5mm white LEDs.
But I still think that $35 is a bit too pricey -
use of 2x CR123A - seems to be overkill -
but there is no denying the performance results -
I am impressed - but less by its current price -
I wouldn't pay that price.
Size comparison
Heads
