NewBie
*Retired*
Re: OMAGAWD ! - OStar Maglight 2D
The four die 10W device
Remember, OSRAM's OSTAR parts are also measured with the die at 25C for a very short blip in time:
"1)Brightness groups are tested at a current pulse duration of 25*ms and a tolerance of ±*11%. Condition for luminous intensity measurement acc. to CIE127 condition A"
While cold, their efficiency is 25 lm/W @ 700mA, and it drops from here.
Typical lumens for their *four* die part is 280 lumens (when it is cold, during the first 1/40th of a second, it falls from here), at 15Vf * 700mA = 10.5 Watts.
Heating can cause a 20% drop in output, so if you drive it up at 10.5W, this 280 lumen number can drop to only 224 lumens.
This is all before reflector and lens losses. After that is said and done, you are looking at ~156.8 lumens out the front.
http://catalog.osram-os.com/media/_en/Graphics/00037308_0.pdf
If you were using the six die 16W device
While cold, their efficiency is 27 lm/W @ 700mA, and it drops from here.
Typical lumens for their *SIX* die part is 420 lumens (when it is cold, during the first 1/40th of a second, it falls from here), at 22.5Vf * 700mA = 15.75 Watts.
Heating can cause a 20% drop in output, so if you drive it up at 15.75W, this 420 lumen number can drop to only 336 lumens.
This is all before reflector and lens losses. After that is said and done, you are looking at ~235.2 lumens out the front.
http://catalog.osram-os.com/media/_en/Graphics/00037311_0.pdf
