- Joined
- Nov 27, 2001
- Messages
- 2,352
- City & State/Province
- Remote NEast Minnesota, next to Lake Superior
Updating. Thought I'd put it here and add a new post at end. Looking for a new CPAP now, and thinking somebody here might know of a more efficient unit, and/or a great battery pack
I thought this went better here than in the Battery Forum as that specifies Flashlight Electronics, however if a Moderator wants to move it, feel free.
I'll sum up the long story below. I need a battery pack that will power a 3A, 12V draw for 8 hours, better would be 16 hours to allow an extra day between charges. It needs to be capable of 5-7 charge/discharge cycles a week as well as car travel on country roads for 20 minutes to and from charging. The ideal would be an easily portable 'pack' with a 12v female accessory (cigarette) socket.
I use a CPAP machine for help in breathing while I sleep. The machine works well and helps reduce snoring. However I live off grid, during the winter I don't like using up my hard won solar power. So I persuaded my insurance company to get me a battery pack when I started using it, I could get about a night and a half worth of power out of the pack. After about 8 months of fairly consistent use, it is down to about 4-5 hours of power. The medical supply provider replaced the pack without much problem. However I have a feeling the chemistry of the pack is the problem. It uses two "gel cells" giving a rated 14.4 AH @ 12V. My guess is the 5-7 times a week discharge/recharge cycle will kill this pack also. The bouncing back and forth between home and shop probably doesn't help much either. So I'm looking, in anticipation of failure, for a different pack. Any suggestions are welcome.
A different machine might be an option also. That one has a Lithium-Ion pack.
