13,300-lumen LED
It takes 800 watts, i wouldnt count on it being used in a flashlight just yet...
Wow,
That is one bright LED! But then I had an Osram bulb that made 10,000 lumens out of only 250W /ubbthreads/images/graemlins/tongue.gif
Wilkey
No only that, but it is a array. Arrays are only good for a flood beam. It is hard to build a reflector around a array. You could do it with lenses, but that would be a custom setup and complicated with the sizing.
Also, I think this array was discused in another thread.
You can make pencil-thin beams that throw all the way to the horizon with arrays, but the optics are potentially just as costly as the array itself - and far more complex.
Maybe we could power it with 266 cr 123 batteries and use fiber optics to give a spot beam, putting both the battery holder and leds into a back pack you wear or you wheel around. Then you have a hose the light comes out of.
