Leef
Here's something I read today and wondered the obvious -- would ultracapacitors be a good power storage option for flashlights, esp. LED lights. Maybe the lower energy storage capacity is the hangup. Anyone know?
Ultracapacitors are a newly developed technology positioned between the conventional capacitors and rechargeable batteries. Ultracapacitors offer a shift in thought, circumventing the battery scramble, and instead extracts greater efficiency from existing power sources. Ultracapacitors are free from the characteristic battery problems of limited cycle life, cold intolerance and critical charging rates. They are also environmentally friendly, help conserve energy, and enhance the performance and portability of consumer devices.
Ultracapacitors can be used to replace batteries in outdoor solar-lighting products. Although their energy capacity is not as great as that of batteries, it is enough to light areas in gardens, driveways, paths and mark roads. In solar lighting, the ultracapacitor has many advantages over batteries.
Ultracapacitors vs. Batteries for Solar Lighting Systems
Rechargeable batteries generate and consume electricity by chemical reaction. This leads to slower responses and the deterioration of performance over time. Usually the charge/discharge cycle is ~1,000 times at best. At this cycle rate, the rechargeable battery has to be replaced every 2-3 years. In addition, the operating temperature range of the rechargeable batteries is very narrow, from 0~45°C (32~113°F). Beyond this range, the performance of the rechargeable batteries drops rapidly. And so the proper working environment of the battery-based solar lighting system is limited. They require maintenance every 2-3 years and have a narrow working temperature range.
Ultracapacitors address the drawbacks of rechargeable batteries for solar based lighting systems. Utracapacitors are fast responding and show no deterioration of performance over time. The charge/discharge cycle of the ultracapacitor is more than 100,000 times. This translates into 273 years of continuous operation making it ideal for path lighting and buried traffic lighting. (One cycle of charge and discharge for solar lighting system is one day.)
- Ultracapacitors transfer electrical charges between conducting materials. They can be charged and discharged almost indefinitely. This removes the annoying maintenance problem.
- Batteries work as a result of chemical reactions and can last ~1000 cycles.
- The ultracapacitor can also be charged effectively regardless of weather conditions.
