I think the super caps are probably going to take over batteries eventually. Unless there are some huge battery breakthroughs.
Super caps have about 10,000 time the density of an average cap.. you can usually always trust wiki:
"In contrast with traditional capacitors, supercapacitors do not have a conventional dielectric, as such. They are based on a structure that contains an electrical double layer. In a double layer, the effective thickness of the "dielectric" is exceedingly thin—on the order of nanometers—and that, combined with the very large surface area, is responsible for their extraordinarily high capacitances in practical sizes."
"In terms of energy density, existing commercial supercapacitors range around 0.5 to 10 W·h/kg, with the standardized cells available from
Maxwell Technologies rated at 6 W·h/kg. Experimental supercapacitors from the MIT LEES project have demonstrated densities of 30 W·h/kg and appear to be scalable to 60 W·h/kg in the short term,
[5] while
EEStor claims their examples will offer capacities on the order of 200 to 300 W·h/kg. For comparison, a conventional
lead-acid battery is typically 30 to 40 W·h/kg, modern
lithium-ion batteries are about 120 W·h/kg, and in an automobile applications gasoline has a net calorific value (NCV) of around 12,000 W·h/kg operating at a 20% tank-to-wheel efficiency."
http://en.wikipedia.org/wiki/Supercapacitor
Very interesting article.
