Glass for bike square light
zgurl
Lyon, France
Hi,
still on my way to the builing of my bike light... I will use square aluminium tubes (like nightrider) and Mcr reflectors but I am wondering how I could close the reflector ends to protect from outside? What sort of glass can I use there? Is there any square possibility or do I need to use round ones + epoxy all around :barf:
Thanks in advance.
PS: my current options are Fatman+4xCrees+McR19xr+6NiMh or 2x18650, this should give me good autonomy at a good brightness level (around 200mA) with full possibility of total power (4x1A, for a limited time only :grin2: )
nightrider
NW Florida
I have used a 1/16" thick acrylic sheet lens to cover my lights. This is commonly known as Plexiglass or Perspex. It is supposed to transmit about 93% of the light that passes through it, which might be less efficient that mineral glass, but it is more durable and readily available.
I usually just cut one rectangle and cover the entire front of the light. If you just put a lens over your reflectors, water could still get down to your emitters (assuming you're following my design).
Here is a shot of my latest Triple Seoul P4 (u-bin). I cut out the middle two ribs so that the plexiglass could recess inside the front frame of the light. It is sealed in place with silicone caulk.
I added the photo below that shows the lens better. I got a little sloppy with the silicone.
Hope this helps and good luck with your light!
zgurl
Lyon, France
Thanks nightrider!
I did not really know wether Plexiglass would be good enough for light transmission, but I will try and I think nobody will see those 7% of brightness loss :)
greenlight
chill valley
I saw square collimating lenses on CPF sometime last week. I was wondering what the use for square reflectors would be. Now I know. They were available with different patterns for different uses. Maybe someone will know the link.
Square Optics
Brum
NL
LEDIL? Work and fit perfectly in the square tubing. They've got optics for both Cree and SSC. They come in 5 different beam angles.
sfCyclotourist
Somewhere I read a suggestion about cutting up the clear plastic from a CD case to use as lenses for an LED bike light. Would that work?
Sawtooth
New Mexico
I think it would be too brittle...
Ken_McE
Any glass shop can cut you a rectangular piece of glass. They just need to know what size. Myself, I'd go for 1/8 inch Lexan in this application. They can cut that too.
