Ultrafire K500L Cree P4 XRE (Lundy)
ernsanada
I just got the Ultrafire K500L Cree P4 XRE (Lundy) from Kaidomain. http://kaidomain.com/WEBUI/ProductDetail.aspx?TranID=1429
Shipping took 12 days.
Fit and finish is good.
Type II Anodize has some spots (not anodized). Looks like it was scratched in some spots.
OP Reflector, aluminum.
Glass lens.
1 stage reverse clickie.
Uses 2, 18650 Batteries. AW's Protected 18650 fit with no problems. Used small magnet to make contact with the Cree Module. Testing purposes to see if the light worked.
Beam tint has slight yellow corona.
ernsanada
Sorry!
I hope to do some beam shots soon.
Also some disassembled shots.
No time today. I received 2 lights and the M3 Turbo Head today.
ernsanada
Ultrafire K500L @ 92"
Lumapower D-Mini OP @ 92"
Ultrafire K500L @ 92" Stepped down exposure.
Lumapower D-Mini OP @ 92" Stepped down exposure.
Left, Ultrafire K500L. Right, Lumapower D-Mini OP @ 92"
Left, Ultrafire K500L. Right, Lumapower D-Mini OP @ 92" Stepped down exposure.
At night the Ultrafire K500L beam tint looks like a yellowish slight green tint.
ernsanada
Size comparison.
Left, Ultrafire K500L Cree P4 XRE (Lundy). Right, Lumapower DX1
All o-rings came generously lubed.
The Cree Reflector assembly screw into the lens bezel.
Ample room for AW's Protected 18650 Battery.
Inside of the reverse clickie.
Lobo
Sweden
Thanks for yet another very nice review. Was a bit curious about this light. Thought it should be MUCH brighter. Looks a bit dim for the size and two 18650? What's your opinion?
ernsanada
Yes I thought it would be much brighter than the D-Mini. The D-mini is using 1 Protected RCR123 vs the 2 Protected 18650.
ernsanada
The bezel causes this shape.
Ultrafire K500L Cree P4 XRE (Lundy) @ 37"
Ultrafire K500L Cree P4 XRE (Lundy) @ 37" Stepped down exposure.
beefy6969
Bay Area, CA
Thank you for this review Ersanada!
This light seems to be an underperformer.
The body looks exactly like the Super Thrower. http://www.dealextreme.com/details.dx/sku.3356
Goes to show you what the right reflector can do. The reflector was designed poorly. There is too much flat space around the emitter. The reflector should be more like a cone. I also heard that the runtime on this sux. Thats just plain wierd since it uses (2)18650.
Thanks again for the review!
2xTrinity
California
According to the DX description, it delivers 900mA to the emitter, and two 1800mA batteries last just under 2 hours, that translates to about 900mA from the batteries. That tells me they're just using a Linear Regulator, rather than a buck circuit -- meaning any voltage higher than 3.7 is just bypassed into a resistor and wasted.
