moon lander
Hello, im in need of a little advice on how to power 4 cree leds with batteries. My current setup has 2 cree p4s in parallel powered by 1 18650 li-ion in direct drive. I know this is not ideal because if the vf of one of the leds is lower than the other, they will draw different currents, resulting in one brighter/hotter than the other. The setup works well however, 1.85amp draw from battery. Good heatsink on this light keeps them cool (the bike itself connects to the heatsink and draws alot of heat away.
Id like to add 2 more leds for a total of 4 Cree p4s. Id also like to drive them harder (at least 1 amp each). ideally id like it if they each drew the same current as well. runtime isnt terribly important at the moment but it cant hurt. here are some possibilities ive been considering.
#1 create a 2s pack- charge the batteries seperately to the same voltage, and then wire them is series, and wire the leds as 2 strings of 2 (2s2p). i realize i will have to make sure the voltage of the 2 cells stays the same, and charge them separately. i dont have the dough to get a balancing charger.
#2 create a 2p pack- charge the batteries separately to the same voltage, and then use them in parallel with 4 parallel leds. problem here is the led vf right? they may all run at a different current.
#3 run all 4 leds in parallel from 1 18650. with a short runtime, this is possibe right? does anyone know the max discharge rate of these unprotected 18650s from DX?
another option is to get a driver, but do they make a driver that will power 4 leds? or could i use 4 of these 750ma drivers from Kaidomain all on the same battery? or maybe 2 to a battery?
if anyone has any answers to these questions, i will be eternally grateful. im a bit of a noob when it comes to batteries (i do understand the dangers of li-ion) im happy to do lots of research, just need a starting point. thanks so much for your help.
