ANOTHER bike light!
aljsk8
Wigan, UK
heres my attempt at the box light originally designed by nightrider
its got 2 cree in at the mo but the 3rd slot will get filled when i get a better battery
also the mount is being fixed on today
here it is....
i made it in 2 parts
the front case is made from 3 cut 1inch square aluminum tubes jb welded together then covered in carbon fiber sheet (cut by supplier) and lexan front - all this is jb welded / epoxied together
then the gizmo part is also square tube with circuit, switch, wiring etc all stuffed in
this slides into the other part and 2 long screws hold it all in (although its a tight fit anyway
heres some more pics
you might be able to see the balloon - thats got the driver inside it to keep it waterproof
the rest of the case is rainproof but some water will inevitably get inside
let me know what you think
RustyKnee
England
it gets hot but im not going to get concerned - crees are cheep let them fry!
lol.
they do lose a fair chunk of light output when they get hot though.
Is it hot when in air flow, or just when its staionary? not criticising...just curious.
The carbon makes it look cool as (not the temerature variety hehe).
Stu
aljsk8
Wigan, UK
only just finished building it so ill try and test it out later tonight but up to now just hot when stationary
i got all the aluminum and carbon parts cut when i ordered them so it would all fit together nicely - which has paid off. the only bit thats disappointing is some of the gluing but the camera shows it up more than looking at it in real life
cant wait to try it out!!
Alex
aljsk8
Wigan, UK
cheers for the comments
ill charge my camera up tonight and take some beamshots
although you all know what 300 - 400 lumens looks like!
cant wait to get another cree in there
alex
Christexan
Carbon, in various forms (including solid diamond) can be an incredibly good heatsink material, however the typical resins used to make standard carbon fiber sheets are not good for the purpose, so unless it's a specific "thermal" carbon material (carbon foam used in racing radiators for instance), it's probably lousy for heatsinking. Good for looks though! If you took raw carbon fiber cloth, mixed it with Arctic Alumina or Arctic Silver, vacuum bagged it down to a tiny concentration of resin, you might make something pretty nice for a heatsink... might not though, haven't tried it, experiment at own risk.
aljsk8
Wigan, UK
tried the light last night - just gets barely warm - i also checked to see if thats because the carbon is holding the heat in but the metal part is only warm too
was awesome riding through the trees with it on!
ill try to get some more shots later (beamshots etc)
Swallow
:twothumbsDigging the retro purple anodised nuts. Carbon is pretty darn sexy too!!:twothumbs
sortafast
Oregon
those purple nylock nuts are the cats pajamas. Now you just need the matching purple hubs and headset :D
aljsk8
Wigan, UK
ok
heres the light mounted on my bike
funny how my camera shows up the glue and construction flaws a lot more than my eyes do
but as for beamshots it picks them up badly - the light looks twice as bright as it does in these shots
heres what it looks like if im coming towards you - except its blindingly brighter
thanks for looking
Alex
barkingmad
The PT EOS 'headlamp' is also available with a bike mount - they are easy to Mod with a Seoul star - two / three of those would give a lot of light and you can either keep with the stock optic or swap for different reflectors for more throw / flood.
