TigerhawkT3
After three failed bike light builds, I finally made something that functioned on a basic level and was actually practical to use, as well.
First try: SOB750 powering a Cree behind a McR17XR. Reason for failure: reflector shorted the solder blobs on the Cree pads.
Second try: Four $12.50 DX Cree modules in parallel, with one flood and the rest focused. Reason for failure: couldn't figure out how to aim/mount the thing.
Third try: A DX AMC7135 board, with two extra switches to activate two of the four AMC7135 circuits. Reason for failure: tiny solder points and big wire don't mix.
The fourth one (that worked): A DX AMC7135 board (1.4A) with three of the circuits activated (around 1A) powering a DX Cree on a 13mm base, behind the reflector from the first try. I've got the Cree mounted on a small, flat aluminum cylinder, with the board behind it. All the components are packed into a little aluminum tube, with polycarb on the front and back (which I cut and shaped myself). I have two batteries, each consisting of 3C NiMHs end-to-end soldered, with quick-connect terminals on the ends. This way, I can connect them in series and charge them with my 5-10 cell pack charger.
I tried it out about an hour ago, and it works! I went kind of slow, since I hadn't ridden a bike in years and I didn't have too much confidence in the twist ties holding the battery and wires to the frame. I'm quite satisfied with it (or, I will be until I go nuts and mount an automotive HID system to my bike).
I'll have pics tomorrow.
