i just bought a klarus xt11 on ebay and it came with a charger and two ultrafire 18650 batteries. before and after charging one of the batteries causes the light to strope/flash. any idea as to what the problem is?
Probably the battery is no good. I have several UF 3000 cells that are between junk and no better than the 2400 mah cells.
A lot of lights cut off when the voltage is too low. Light on voltage drops then light off so voltage goes up then light off again ad infinitum.
It is recommended that every Li-ion user buy a digital multi-meter (DMM). Then you can test and verify cell voltage, especially when you put two cells in series so you can verify the voltage matches.
