according to the documentation it doesn't shut off but blinks.I am sure the Fenix Headlamp shuts off to prevent overdischarge as quality 18650 lights have that built into the circuitry
HKJ here on the forum and/or on his web page has miles of reviews of cells. chargers, and I think charger/powerbank combos. Worth checking out.
From what is widely available in the USA, I have always had good results with Xtar and Nitecore chargers, Sony and Sanyo 18650 cells.yes I did look at his page, I find it quite overwhelming, what would be good if I got some recommendations for 18650 and a good reliable charger combo.
But maybe I'd have to open a separate thread for this.
Depends on what you use the headlamp for...built in low battery protection which shuts off the lamp is safer than a blinking light.
In some situations, a headlamp that switches off to protect the battery from overdischarge, could be far more dangerous than a headlamp that dims or starts blinking. Think people climbing in caves, mountain biking at night, people working on oil rigs, miners, etc. In such a situation, better damage a cell & keep seeing something (be it vaguely or flashing) than be totally in the dark just when it counts.
Replacement cells are cheap - accidents often are not.
the Fenix HL 50 I use gives about 150 LM and runs for about an hour and a half before stepping down.I have several Zebralights. You won't be left in the dark from a low battery. It steps down as the battery voltage gets low. The final step-down is to low (a few lumens), and that runs for several more hours before it finally shuts off completely.
I suppose the only way you might be surprised, is if you normally only use the light on low. In that case, it would just shut off when the voltage reaches around 2.7v. But you would have to run the light for more than 2 weeks straight before you drained the battery on low!
yes I used this when it arrived, the battery was fairly empty, as it should I believe for transport.If you don't know the state of your battery before you go out, do a quad-click. It will blink out the battery charge (from 1 to 4 blinks). It's not a perfect measurement, but it's close enough.
this is the reason I started to research lithium again, the difference between nimh and lithium is getting to be an enormous.Finally it sunk in.... lithium ion just has HUGE power density compared to nimh there really isn't much comparison
IMO it was a game changer for me. Once I decided on 18650 format and lithium ion it was then just a matter of finding a good headlamp. I recently received a Sofirn SP32 in the mail and it is a nice 18650 light with close to perfect spacing of the modes and no blinking modes to stumble through just 4 modes and access Turbo with a double click. I have 3 or 4 cheap 18650 lights with Chinese clone emitters that work well enough for the price but none can match even the high mode on this light not to even think of the Turbo. After getting this light I wish I had bought another one as the price went up about $12.this is the reason I started to research lithium again, the difference between nimh and lithium is getting to be an enormous.
