18650 protected batteries
dynamiccoins
Hi,
I am planning on using Xtar 18650 3.7V, 3100mAh with my Ultrafire 501b, but i was wondering if its bad to run the light till the battery protection kicks in.
Does tripping the protection damage the battery itself?
Thanks
The protection circuit for the low voltage should kick in way above the level which will damage the cell.
Most protected cells cut off ard 3.3 - 3.5v & your cell should be able to take discharging all the way till 2.9v..
- JonK
The risk of relying on the protection circuit is if it were to fail (it's a $0.05 part after all) and you didn't realize it. Then low voltage would damaged the cell, destabilize the chemistry, and then it starts to become a vent-with-flame risk when you go to charge it. Risk is minimized if you always meter the cell before and after every charge.
