B B30wuLF Newly Enlightened Joined Oct 16, 2008 Messages 46 Mar 28, 2009 #1 does someone sell 18650 to D cell adapters here? or do you have some plans? i want to fit 5 18650 in to my 6d mag
gillestugan Enlightened Joined Nov 20, 2007 Messages 242 Location Nora, Sweden Mar 28, 2009 #2 a hammer may work the D cell is a few mm shorter than a 18650. you should be able to put 5 of them in a 6d mag if you use a spacer. maybe you can use some rubber or plastic tubing around your cells.
D Der Wichtel Enlightened Joined Mar 12, 2007 Messages 829 Location Germany Mar 28, 2009 #3 you can use cheap pipe isolation
DUQ Flashlight Enthusiast Joined Jun 22, 2005 Messages 1,824 Location Ottawa, Ontario, Canada Mar 28, 2009 #4 Der Wichtel said: you can use cheap pipe isolation Click to expand... Works very well.
