2 maxflex 1 button.
marcopolo
Has anyone tried controlling 2 Bflex or Maxflex drivers from just 1 switch? for instance say you wanted to control 2 separate banks of LED's with just the 1 push button switch connected to both drivers in a dual headlight system? The idea is so save pressing 2 buttons to change levels etc..and to program.
I know on the bflex you can master slave config - but no such thing exists on the maxflex.
Marco.
never heard of anyone doing it with a maxflex best bet would be to ask George .
could you not use a double pole mom switch and as long as you have both lights in sync then it should work ok
I think the advice was they end up getting out of sync due to noise/switch bounce/whatever. There are two way mom switches which means you could individually control each maxflex, or use that as the backup to the single switch(when they get out of sync).
