Guys, think for a second a 2xAA, metal tube construction. Something like a Maglite Mini AA. I just inspected my rechargeable NiMh AA batteries and found a couple of them with damaged insulator around the body (especially around the (-) end) - this comes from repeated insertion/extraction from all kind of carriers, including the one in the charger. And the plastic shirt on the batteries gets chipped/cut on that end quite easily with some brands (as the material is rather thin and frail).
Now if I insert such damaged battery in the head end of a 2xAA metal flashlight, and its casing makes contact with the metal body through such insulation defect, it will definitely short-circuit the battery installed at the tail end (which by design is connected with the (-) to the flashlight body and with the (+) to the external casing of the next battery, which now connects to the body too). So the tail end battery will either leak (alkalines), overheat (NiMh) or even explode (Li).
My question is - given that the insulation on the body of the batteries is not stellar these days - why don't flashlight manufacturers insert a plastic tube inside the metal tube, to make sure that in case you use a battery with damaged insulation, you don't short-circuit the other batteries installed in series with it?
Or, if some manufacturer actually does it, can you guys recommend it?
Nap.
Nap.
