J.McDonald Knives
Since the Shoppe is down is there another place to buy an aspheric lens with a great throw?
I think that the FL is too big, for reference the regular Mag has a 35 - 38 mm fl, and my custom Lumapower M1 has a 15 mm FL something between 15 - 20mm would be more suitable for a minimag, IMO.
Can you measure the distance between the inside glass and the yellow emmiter surface? That distance would be your focal lenght IIRC
AlexGT
J.[B said:[FONT=Arial, Helvetica, sans-serif][/FONT][/B]
What kind of convex lens would be best? Is is plano, double, or what?
I think that the DCX or double convex is slimmer than the PCX or Plano convex, IIRC as long as it's aspherical the result will be the same IMO.
BTW did you measure the distance from the glass to the led? Is your minimag a regular short bezel or a Magled with the longer bezel? This will affect the distance of the FL.
AlexGT
I have ordered a few PCX lenses from Anchor to try in my Terralux driven minimag. When they arrive (early next week I hope) I'll let you know how it goes. Aspheric/PCX lenses like these are somewhat difficult to find on a flashaholic budget because the FL is shorter than the lens diameter in most instances. Experimental grade optics are about as cheap as you can get, and really they're ideal for flashlights. The lens I have on order has a 23mm FL, so I think it'll be ok. I also got a few to try in other lights.. a 6P Clone and a Fenix T1. Pocket throwers for the win! :twothumbs
EDIT: This post was to address the optics questions above my previous post.
I dont think you really want a DCX. It'll refocus the light to a point at the focal length, which, at the lengths you'd use a flashlight for, will nullify the use of the optic. You need a collimating lens, like a PCX.
