Since the H9 is 65 watts, and the H11 was 55 watts do you need to upgrade the wiring harness as well? Thx
I had a discussion with a moderator from another lighting forum regarding the cons of putting a HID conversion kit in a halogen projector. Besides the obvious focal point issue of the re-based bulb he also noted that these kits could cause problems such as running too hot or burning the chrome bowl due to higher UV radiation.
I take it you guys would recommend the Philips 9011 HIR1 for the 9005 high beam upgrade?
