Fenix has new series of flashlights that are CR123 based called the "PD" series - they are basically "P" (xD) series updated -
There are obvious cosmetic changes.
Once again this Fenix PD20 is through the very kind courtesy of 4sevens -
it's a single CR123 light using a "Premium" Cree XR-E - Q5 emitter - with updated cosmetic changes - which I think makes it look very attractive.
For me one of the main improvement is the 4 anti-roll flats on the octagonal nut-like part of the head.
Size -
Head -
So is the PD20 just a P2D in different clothing?
Not quite -
vs. P2D-Q5 both Turbo and primary CR123 -
close - they are both rated at 180 lumens - I think the P2D-Q5 may look less bright because it spreads its light out more with a wider beam.
vs. Fenix P2D-RB100 both Turbo and primary CR123 -
again close - but this time I think the PD20 may just have it, although I think the P2D-RB100 may look less bright because it spreads its light out even more with a noticably wider beam.
vs. NiteCore EX10 Max primary CR123 -
Close
Note: this is that over-achiever NiteCore EX10 - which caused all the fuss in NiteCore Lumens Rating - I discovered it was "faulty" - as it would switch off of its own accord - although it had not done that for the one month previously - and has not done it since. I still consider it an exception - as it is brighter than norm.
Remember the PD20 is rated 180 lumens - and NiteCore EX10 is rated at a mere 130 lumens albeit torch or OTF (Out The Front) lumens.
Just out of interest I also compared the EX10 on 3.7V rechargeable Li-Ion RCR123 -
vs. NiteCore EX10 Max, but on 3.7v Rechargeable Li-Ion RCR123
in these shots the EX10 on Li-Ion may look slightly brighter than in the primary CR123 shots - but there is still not much in it.
vs. LD20-Q5 - Turbo 2x NiMH AA
close - there ought to be very little, if any, difference as they are both rated at 180 lumens and the heads are the same/interchangable. This one sample of the LD20 may have its emitter out of the sweet spot as it shows rings and the dark halo more than any of the others on the newer Fenix series - like LD10, PD20 and PD30.
vs. PD30-Q5 - Turbo 2x primary CR123
hard call - but the PD30 is brighter as it is 220 vs. 180 lumens whch is an increase of 22%.
Should note I thought this PD20-Q5 has one of the best tints I've seen on a Cree Q5 - of course it is still not as good as my old stand-by the RB100......
Index to Follow Up Parts -
Standardized Stairway beamshot - Post #19
Size -
Head -
Not quite -
Close
