Hello,
I've just bought my first power LED: a red-orange Luxeon I.
I'd like to power it from two AA NiMH in series (so Vbat ranges from 2.7 V to 2.4 V for most of the runtime).
According to the datasheet for this LED Vf should be around 2.3V @ 70mA, and 2.6V @ 200mA.
So I tried connecting my LED directly to the batteries (Vbat=2.7V), expecting the current to be around 200mA or slightly more.
But I measured only 70mA, and the actual Vf was 2.6V.
So I tried with three NiMH in series, i.e. Vbat= 4V. I put a variable resistor just in case, to avoid any damage to the LED.
From the datasheet Vf=2.5V @ 150mA.
So doing the easy maths, Vbat-Vf=1.3V, so to get 150mA I need a 9 ohm resistor. But with this setup I measured only slightly more than 100mA.
Then I tried to adjust the resistor value until I got the expected 150mA: it turned out to be 3.2 ohms, and Vf=2.8V instead of 2.5V from the specs.
Now completely removing the resistor, the current only reaches 194mA, and Vf=3.3V whereas the specs say it should be 2.6V @ 200mA.
Next I put back the variable resistor (still with 3 NiMH) and adjusted it until the current was 70mA, like in my first attempt with 2 NiMH. I then measured Vf and found 2.33V, i.e. a much lower value than when I connected the LED to 2 NiMH and got 70mA. Strange.
How come I find such a difference with the Vf/I chart in the specs?
How come I can't get more than 194mA when driving it direct from a 4V battery set?
Why do I find different values for Vf at the same current, depending on Vbat?
At this stage I should mention that I had trouble soldering the leads on the LED star pads (it was my first time) so I may have overheated the LED. Could this be the reason for these off-specs values?
