ernsanada
- Joined
- Apr 29, 2004
- Messages
- 2,962
I just purchased the Dorcy Rechargeable Cree XRE from Dorcy Direct for $43.99. There was a special, receive 20% off. I used the code HOLIDAY20. I opted for free shipping. There is another holiday special 15% off use HOLIDAY. I'm not sure if the HOLIDAY20 special is still working.
The Dorcy Rechargeable uses a nicad battery. Voltage is 4.8V, 700mAh. Before charging remove the insulator insert before using. Dorcy tells you to do the intial charge for 12 hours. After that recharge time is 4 hrs. Run time is rated for 2 hours. There is a charging port behind the reverse clickie one level switch. Just loose the tubing behind the switch.
The Dorcy comes with an AC charger and a 12V car charger. Not a bad deal for the price. I noticed on the Dorcy website that parts are offered such as another rechargeable battery if needed. Maybe you may need a spare or if your battery starts to die after using it a lot.
I pleasently surprised at the build quality. The fit is excellent, threads are smooth. I like the knurling on the battery tube, it gives some grip to the light. The Dorcy feels well balanced in my hand. I give the grade A.
I'm not sure of the finish but it's probably Type II Anodize. No flaws in the finish. I give the grade A.
The Dorcy comes apart very easy. Nothing glued!
The switch is a side one level reverse clickie. It's on the stiff side to push. Maybe it's a good thing because the switch won't be accidently activated.
The lens of the Dorcy is made of plastic and measures at 51.97mm. The thickness of the lens is 1.04mm. A Maglite UCL will fit but the lens bezel assembly will have some threads showing.
Th reflector is also made of plastic and it's a SMO. The length is 56.65mm and the width is 51.65mm. The reflector uses a gasket at the widest opening between the lens.
The color of the tint of the Cree is a cool white. The beam has the typical rings due to the SMO.
I found this information in a thread about this light.
Drive current is 1000Ma
Vf is 4.8 V
Cree Q4 rated at 220 Lm at 1000Ma
Non regulated drive circuit so initial current is present when batteries are fully charged.
I am very surprised at the lux readings I got. It's in the same range of the Dereelight DBS V2 Q5 3S and the Tiablo A10 R2 I have.
Reverse view of the Cree module.
Lens bezel assembly. A Maglite UCL will fit but some threads will show when he lens bezel assembly is screwed down. Measures 51.65mm.
SMO made of plastic.
Length is 46.26mm. Black gasket located on the front.
Uses a one level reverse clickie.
Dorcy is printed on both side of the "flats".
Charging port located behind the single level reverse clickie. Rotate the "movable tube" counterclockwise to open. Clockwise to close.
No o-rings used in the "movable tube", so watch the water!
AC 100-240V
AC charger included.
12V car charger included.
Remove the insulator insert before using.
Nicad battery. Voltage is 4.8V, 700mAh.
Rear tailcap inside view.
Has the words "China" imprinted on the outside if the tailcap.
__________________________________
Size comparsions.
Left to right, Dorcy Rechargeable Cree XRE, Dereelight DBS V2 Q5 3S, Tiablo A10 R2 WC
I also took lux readings of the lights shown above. These are the lux readings I got. I am using a Meterman LM631 Light Meter measured at 1 meter. I waited 2 minutes before taking the readings. I am using AW's Protected Black 18650's and AW's Protected RCR123's which were fully charged. The Dorcy uses a nicad voltage is 4.8V, 700mAh.
Dorcy Rechargeable Cree XRE - 22,050 lux @ 1 meter
Dereelight DBS V2 Q5 3S, 18650 - 20,767 lux @ 1 meter
Tiablo A10 R2 WC, 18650 - 21300 lux @ 1 meter
Tiablo A10 R2 WC, 2 RCR123's - 21730 lux @ 1 meter
Note, this lux reading I got on the Dorcy Rechargeable Cree XRE was on the initial charge of the light. The lux reading may improve a little in time. Also use an UCL lens the lux reading should also improve. Stock plastic lens used in the lux reading.
Dorcy Rechargeable Cree XRE @ 96"
Dereelight DBS V2 Q5 3S, 18650 @ 96"
Tiablo A10 R2 WC, 18650 @ 96"
Left, Dorcy Rechargeable Cree XRE, Right, Dereelight DBS V2 Q5 3S, 18650 @ 96"
Left, Dorcy Rechargeable Cree XRE, Right, Tiablo A10 R2 WC, 18650 @ 96"
Left, Dorcy Rechargeable Cree XRE, Right, Dereelight DBS V2 Q5 3S, 18650 @ 96" Stepped down exposure
Left, Dorcy Rechargeable Cree XRE, Right, Tiablo A10 R2 WC, 18650 @ 96" Stepped down exposure
Dorcy Rechargeable Cree XRE @ 146' or 44.5 meters
Dereelight DBS V2 Q5 3S @ 146' or 44.5 meters
Tiablo A10 R2 WC, 18650 @ 146' or 44.5 meters
Dorcy Rechargeable Cree XRE @ 210' or 64 meters
Dereelight DBS V2 Q5 3S @ 210' or 64 meters
Tiablo A10 R2 WC, 18650 @ 210' or 64 meters
Beam shots taken against buildings. At this time distance unknown.
Tiablo A10 R2 WC
Dorcy Rechargeable Cree XRE Stepped down exposure
Dereelight DBS V2 Q5 3S Stepped down exposure
Tiablo A10 R2 WC Stepped down exposure
Vf is 4.8 V
AC 100-240V
Size comparsions.
Tiablo A10 R2 WC
