MWClint
Older Brass Matterhorn modded with a Seoul High CRI 4000K P4 and a Dorcy 1xAAA circuit.
Once the potting dries, it is going back on my keychain..it rocks!
First, grind out the potting of the matterhorn head with a dremel..there's no
other way really..it will destroy the peak's guts..so we'll need a small boost
circuit to replace it... for simplicity, the dorcy 1xAAA light makes a perfect
donor for the circuit. You do have to grind away the edges of the circuit to
allow it to fit inside the peak's head. And you will have to grind some material
out of the inside of the matterhorn head..but not much.
It is considerably brighter and the warm glow pairs up nicely with the brass.
Knurling removed with a dremel/400-2000 grit sandpaper and then Polished with flitz.
business end
Have a few of these old matterhorns, so here's a beamshot comparison..
dorcy circuit inside the matterhorn head. I dumped in some silicone goop
to seal it up..it's currently drying.
business end
