VanIsleDSM
Specs:
Precision machined to fit genuine surefire and FM26XXX P60 hosts.
Single Li-Ion cell operation for energy density and safety.
LEDs individually current regulated.
Integrated thermal shutdown.
Reverse polarity protection. Upside down battery causes no harm.
2KV ESD protection. Resistant to static shock from your fingers.
Low battery warning (drops to low mode and intermittently flashes off quickly).
Mil-Spec Teflon insulated oxygen free silver plated copper conductors.
Silver plated beryllium copper ground spring with gold plated contact.
Gold plated positive contact.
Cushioned shock resistant driver.
Modified Khatod Italian made 10 degree FWHM (tested with XPE) beam. Tightest beam possible from P60 multi-LED engine. More common Carclo optics pictured for comparison are 16.4 degree FWHM. (Frosted version pictured)
Available Tint and Flux:
R5 Cool white 6200K
R3 Neutral 5000K
R4 Neutral 4000K
Q5 Warm 3000K
Available Driver Mode Configurations:
5 mode: Low - Med - High - Strobe - SOS
3 mode: Low - Med - High
3 mode: Low - High - Strobe
2 mode: Low - High
1 mode: High
5.6A silver plated copper Drop-in:
R5 minimum flux calculates to 1780 lumens.
R4 minimum flux calculates to 1665 lumens.
R3 minimum flux calculates to 1560 lumens.
Q5 minimum flux calculates to 1370 lumens.
Thermal Data:
C101 99.99% pure oxygen free copper thermal conductivity: 391 W/m · oK
99.9% pure silver plating thermal conductivity: 418 W/m · oK
LEDs directly mounted to silver plated copper surface. No MCPCB insulation layer. Lowest thermal resistance path possible without extremely exotic materials (e.g. diamond)
4.2A Aluminum Drop-in
R5 minimum flux calculates to 1450 lumens.
R4 minimum flux calculates to 1355 lumens.
R3 minimum flux calculates to 1270 lumens.
Q5 minimum flux calculates to 1115 lumens.
Thermal Data:
6061 T6 aluminum thermal conductivity: 167 W/m · oK (Heatsink)
Pure aluminum thermal conductivity: 220 W/m · oK (MCPCB)
Bare aluminum for best conduction of heat into host. MCPCB screw torqued to 32 in-lb. creating a clamping force of over 1000 lbs. Arctic Silver 5 thermal paste applied between MCPCB and heatsink.
FETtie high current switch
Information Thread:
https://www.candlepowerforums.com/threads/296127
These solid state switches will handle the high current much better than a regular switch. They are a reverse clicky. The thread has some more information and graphs to show performance.
Warning:
These lights can be dangerous. If left unattended it could get hot enough to cause a failure in the battery, resulting in a possible fire or explosion. Do not point light at eyes or skin. This is a very high power device. Do not run unattended.
