[ QUOTE ]
turbodog said:
Yes I am using rechargeables with it. I can't tell it from a regular e2e beam.
In my opion, it would be a huge waste of time to turn down a pila lamp. The lamp is as expensive as a surefire lamp, and then you've got to go through the trouble of turning it down.
The adapter can be made fairly easily and it's a permanent solution. You could even run 2 r123 cells and an appropriate bulb. Carley has a wide selection that fit the standard stinger/strion socket.
Here is the adapter with a strion bulb in it.
*sucky-out-of-focus /ubbthreads/images/graemlins/wink.gif image disabled by udaman in quote:)*[*image]http://home.jam.rr.com/turbodoggie/e2%20series%20strion%20adapter.jpg[/image]
Plug and play easy.
Great beam.
[/ QUOTE ]
Ah Turbodog, we think alike (unlike them power crazy, Ginseng & js guys). 2 r123's can almost just hit 2a discharge correct? Woohoo, the Carley 1499 is T1.5 sized bi-pin of 7.2v 1.84a, with outstanding efficiency for 385lumens output! yeah baby, twice the output of the standard M*gChr, in an E2e form factor...let's do it! Hmm, how hot would an E2e get with a 13.2w bulb burning inside, regular epoxy would probably burn up? Hehe, it would be the poorman's Mini-me version of the standard SF M6 /ubbthreads/images/graemlins/grin.gif. Voltage sag under such a load, would probably mean an underdriven yellow, rather than white, output /ubbthreads/images/graemlins/frown.gif
I'm supposed to pickup a few 1499's from Carley tomorrow /ubbthreads/images/graemlins/smile.gif Along with some $1.10ea lensed 888's, which aren't much greater in output over the Strion bulb, but allegedly have insane efficiency, 91lumens for only 2.5watts running at the same 3.6v as the Strion--- might even be brighter/whiter than the Strion?.
Err, I did not understand the part with using copper tape? What contacts are difficult to solder, and why?
