3 XR-E's and a MC-E
Packhorse
New Zealand
If you have ready any of my threads you will know I am a fan of dive lights with a tight spot.
But this time I decided I would try and throw some spill in there as well.
Its much the same as my previous can light builds with a couple of changes.
Battery pack 9x18650 2500ma 3P3S
3 XR-E LEDs using aspheric lenses and a MC-E using a reflector
Driver is a Kaidomain 2.8 amp driver running the XR-Es all in parallel and the MC-E seriesed to the XR-E's. Power consumption is about 21 watt.
Switch is a magnet and reed controling a MOSFET.
For referance is a quad XR-E aspheric running at 10 watt.
The pics dont really do the light justice as you cant really see the true amount of side spill.
Bad news is I will never dive with this light, at least not in the short term. Its been made for a diver 800km's away.
No.
I mount them on PVC tubes with acrylic cement and then cut the diameter down to 17mm on the lathe.
Packhorse,
[FONT=&quot]How do you think a 4 x-re with 3 aspherics, and one not for the flood would work?[/FONT]
I think the spill would be some what lacking. Perhaps 2 or each and run them all at 1400ma? (I run my own can light at 1400ma per XR-E)
Packhorse, on this project could you tell what side of the light the MCE was when you would shine it on an object? I am curious if it would be annoying to always have one side floody and the other side torchy.
I dont have it any more but its not something I noticed. Perhaps at very short distanced eg 200mm or less but over that the beams merge.
WOW nice one!!
Did you do anything extra to seal the ma*lite??
How deep it is rated for??
K
Thanks! Your lights get better and better.
Whats next on your list?
Maybe a video light setup, so we can see what diving is like where you live.
sweet packhorse... thanks for the pics... your lights always amaze me...
Someday i'm going to come to the WRC Rally New Zealand and then we can go scuba togethah :D
What happends if the aspheric lens i in direct contact with water? I guess there will be no effect from the lense?
no optics guy here, but I would think, that the focusing distance changes considerably.
I think ( not sure) that a certain company had this exact problem with a light that was produced for them. Looked great on land. Nice sharp beam. But as soon as it was put in the water it turned into a flood light.
When using aspherics under water you need to seal them off so they dont get wet. Otherwise they will not focus the light.
Nice job Packhorse!
What sort of runtime would you expect from this light?
9 x 2500ma x 3.7v=83 watt hours
Power consumption is 21watts.
Theoretical burn time 4 hours on high. 40 hours on low
Although I would treat it like its a 3 hour pack which means by using rules of thirds you could plan a 2 hour dive using it on high. ( and still have at least 1 hour in reserve).
