Warning: pic heavy, as usual. :whistle:
ArmyTek has sent me the latest version of their high-output thrower light, the Barracuda (XM-L2 U3, in the "Limited Edition"). I don't usually go in for cutesy names, but this one as a distinctive ring to it. ;)
Let's see how that extra "oomph" of the XM-L2 U3 helps it, compared to other 2x18650, 4xCR123A throwers. :whistle:
The Barracuda comes in a presentation-style plastic carrying case, in the trademark ArmyTek yellow (actually, more of an orangey-yellow). Inside everything is firmly secured in cut-out foam. You will find the light, manual, spare o-rings and tailcap boot cover, and belt holster. Note the box is just wide enough for the light - there is no padding in front or behind of the light.
Note that like all ArmyTek lights, there are several bezel and emitter choices available for this model. The bundled options are detailed on a sticker on the back of the package. One interesting feature – they even give you a date of manufacture (05/2013 in my case above).
From left to right: AW Protected 18650; ArmyTek Barracuda; Olight M3X; Crelant 7G5CS; Klarus XT-30; Eagletac GX25L2.
ArmyTek Barracuda: Weight 400.8g, Length 264mm, Width (bezel): 64.0mm
Crelant 7G5CS: Weight: 334.5g, Length: 247mm Width (bezel): 64.0mm
Eagletac GX25L2 Turbo: Weight: 320.7g (with battery pack: 412.5g), Length: 251mm, Width (bezel): 62.0mm
Eagletac SX25L2 Turbo: Weight: 343.4g (with battery pack: 534.3g), Length: 255mm, Width (bezel): 62.0mm
Klarus XT30: Weight: 283.1g, Length: 247mm, Width (bezel): 58.0mm
Niwalker 750N1: Weight: 408.0g, Length: 269mm, Width (bezel): 58.6mm
Olight M3X with Extender: Weight 277.8g, Length 244mm, Width (bezel): 62.3mm
Sunwayman T40CS: Weight: 296.7g, Length 227, Width (bezel): 63.5mm
Surefire UB3T: Weight: 311.1g, Length 229mm, Width (bezel): 63.1 mm
Thrunite Catapult V3: Weight: 434.8g, Length: 254mm, Width (bezel) 58.0mm, Width (tailcap) 35.1mm.
The first observation above is that the Barracuda is heavier than most lights in this class (although not quite as heavy as the Thrunite Catapult). It is also slightly longer than most models.
As always with ArmyTek, build quality is very high – and the light has a very robust/substantial feel.
The ArmyTek finish is fairly unique - the body has a very thick matte finish anodizing that feels almost molded or rubberized somehow. :ooo: According to ArmyTek, this coating is much thicker (with harder anodizing) than most lights. Although the light lacks knurling, grip is actually quite decent – much better than you would expect, thanks to the unique finish. And there are some ridge detail elements to help further with grip.
Note the grippier finish may show dirt, hand oil, etc, more easily than traditional glossy knurling. There are also no anti-roll features – the light can roll easily on its side.
Lettering is very bright and clear, and exceptionally legible. In additional to model information on the body tube and bezel, the voltage range and supported cells are printed right on the light.
Screw threads are thick square-cut (trapezoidal), and anodized at the tail region of the battery tube and in the tailcap (for lock-out). :thumbsup:
The tailcap switch is a forward clicky, with good feel. The spring is thicker and longer than typical on these sorts of lights, with a flat connector piece (so as not to scratch your batteries). The Barracuda cannot tailstand
Note the spring in the head, so high capacity flat-top batteries can be used. Another nice touch here – the head spring is flattened down in the middle, so it again won't scratch your cells. All my 18650 cells fit – there is quite a generous amount of cell length space.
The smooth reflector is extremely deep on the ArmyTek Barracuda – deeper than most lights of this class. I would expect excellent throw, but at the expense of spillbeam width. XM-L2 emitter was perfectly centered, with some sort of surrounding mask.
There is a noticeable anti-glare coating on the lens, but this has a different tint to it than most others I've seen (i.e., more green, as you will find on some camera lens and personal glasses). Most flashlight lens anti-glare coatings tend to have a purple fringe. ArmyTek informs me that this is a higher grade anti-glare than commonly used.
There is a black stainless steel bezel ring on my sample (flat), but I believe other bezel styles are available.
User interface of the Barracuda is very straight-forward. Turn the light on/off by the tailcap forward clicky switch (press for momentary, click for locked-on).
You choose output mode by the position of the head – tight for Max, loose for the user-controlled level.
With the head loosened, there are three levels set by soft-pressing or clicking off/on rapidly: Lo > Med > Hi, in repeating loop. Note that Hi a slightly lower output than Max.
There is no permanent mode memory in the head-loosened state - after being off for a few seconds, the light reverts to Lo. However, if you switch from head loose/tight, it remembers the head-loose state (as long as you don't turn it off).
And that's it – no blinky modes. ;)
Video:
PWM/Strobe
As always, there is no sign of PWM at any output level – the Barracuda is current-controlled at all levels. :)
And again, no blinky modes.
For white-wall beamshots below, all lights are on Max output on 2x AW protected 18650 batteries. Lights are about ~0.75 meter from a white wall (with the camera ~1.25 meters back from the wall). Automatic white balance on the camera, to minimize tint differences.
As expected, the Barracuda has outstanding throw – and a much more greatly restricted spillbeam compared to most of the competition. It all really comes down to the reflector design – you can get throw a number of ways with a large reflector.
For outdoor beamshots, these are all done in the style of my earlier 100-yard round-up review. Please see that thread for a discussion of the topography (i.e. the road dips in the distance, to better show you the corona in the mid-ground).
FYI, any "streaks" you see across the images are bug-trails. Flying insects are often attracted to the bright lights, and their flight trails get captured as swirly streaks due to the long exposure time. :)
As you can see, the Barracuda does indeed have a much narrower spillbeam in real life. Throw is top-of-class for 2x18650 family at the moment, although the M3X XM-L2 is pretty close. Again, ignore any tint differences above – they are mainly due to the automatic white balance setting on the camera.
The Barracuda is currently the best throwing 2x18650 reflectored light in my collection at the moment. :) It is also one of the brightest.
On that front, please be aware that a number of high-output lights appear to be consistently under-reported somewhat in my estimated lumen scale. As always, I recommend you use my estimated lumens as a relative guide to comparing lights in my collection, not as an absolute accuracy indicator. But if it helps, here are my estimated lumens at all levels:
The Barracuda has a good range of output levels available.
Output/Runtime Graphs:
The closest Max output and throw comparable to the Barracuda is the Olight M3X XM-L2 (T6 bin). The extra potential of the U3 bin used here translates basically into extended runtime on Max – otherwise, the output/runtime curves looks pretty similar.
That said, ArmyTek is clearly using a very efficient current-controlled driver – the runtimes at all levels are very impressive for this class. :thumbsup: It also has a reasonable spacing of levels.
Like the Olight M3X, the Barracuda is heavily driven on Max, with no automatic step-down feature. As such, I recommend you do not run the light on Max for extended periods of time on primary CR123As.
There is no bundled diffuser with the Barracuda, and it throws a relatively narrower beam than most lights of this class.
There are no anti-roll features for the light, and no place to thread a lanyard. The light cannot tailstand either.
And we have a new champion – the ArmyTek Barracuda takes the crown for the furthest throwing reflector-based 2x18650 light in my collection at the moment. :wave:
It is an outstanding showing, taking us well into the range of some aspherics I've seen in this size. This is about as far my original 6x18650 Olight SR90 was able to throw. :ooo:
More than that, I'm happy to report that ArmyTek is using an excellent current-controlled circuit. Runtimes are impressively flat-regulated, at all levels. Personally, I would like to see a timed step-down feature for Max, but I imagine many here will be happy with this regulation pattern. And output/runtime efficiency is top-of-class – the Barracuda has some impressive runtimes, at all levels (note my testing is done on lower capacity 18650s). :thumbsup:
The build of the Barracuda is very robust. This is a substantial light, and is clearly meant to inspire confidence in its long-term survivability and use. I personally quite like the "grippy" texture of the thick matte ArmyTek anodizing – I've seen plenty of lights with mild knurling that had much poorer grip. Careful care and attention to detail is also evident throughout the light (e.g., I particularly like the robust head and tail springs, flattened or covered to prevent any possible scratching). Although it is odd that no wrist lanyard option is available.
If you are looking for massive throw, I don't think the Barracuda will disappoint. :rolleyes: And as with all the high-output throwers, as long as you use appropriate common-sense about battery configurations on Max, I think you will find this light will meet all your throw cravings.
Barracuda was provided by ArmyTek for this review.
- Limited Edition with Cree XM-L2 U3 LED
- Excellent throw for more than 540 meters
- Maximal light output 1450 LED lumen
- CONSTANT brightness in all modes
- 50 meters waterproof
- Record runtimes in all modes
- Powered by two 18650 Li-Ion or four CR123A batteries
- Volrage range 5-17V
- The reflector is modeled and calculated in computer software for the design of optical systems that enables to produce a flawless light beam for a distance more than 520 meters.
- Ultra-transparent and tempered glass with anti-reflective and lens coating normally used in photo equipment only. The transparency of the glass is 98-99%.
- FLAT runtime technology.
- Advanced electronic protection from incorrect battery installation, without reducing the efficiency of the driver.
- Excellent runtimes for all modes due to high efficient electronics.
- The ability to use batteries with a flat contact. Protection from switching on accidentally (special turn of the tailcap).
- The flashlight has a strong, difficult to break body, which iincludes element design specifically to prevent the flashlight from rolling.
- Impact-resistant bezels from both sides. In the Gold and Black version the steel bezels are also covered by titanium coating with a hardness of 2000-3000HV.
- The electronic driver is placed in a special aluminum capsule and has been completely covered with durable compound. This actually protects it from both the environment and from mechanical damage.
- Body cover: matte, anodized. Hardness: 350-400HV. Resistant to scratches and impacts.
- Body material: aviation-grade aluminum T6061-T6.
- Water resistance standard: IPX-8 (the highest)
- An О-ring has been used to increase glass sealing, and well as an extra L-ring of a specific shape.
- All threads, rubber parts and other parts of the flashlight that experience friction or contact with water are lubricated with a special dense grease NyoGel 760G.
- Included: Plastic Box, Holster, Rubber Button, 2 spare O-rings
- MSRP: ~$150
Video:
PWM/Strobe
