4 AA lights /series or parallel
webley445
St. Pete, Fl.
Any way to be able to tell if a 4AA light runs the batts in series or not. Got burned on a 4AA Energizer swivel head like that.
Easiest way would be to spend the few dollars for a cheap multimeter from Radio Shack and measure the voltage at the socket.
3 voltish and they are 2 pairs in parallel, 6ish volts and they are all in series;)
That may be the best way if you can't get in to actually look at how it's wired.
What I do is check out the replacement bulb. Most all packages tell you what the replacement lamp is. TX
