4 x 5mm LED's off one D cell?
Streak
ex South Africa now SoCal
4 x 5mm LED\'s off one D cell?
I want to run 4 20mA blue LED's off one D cell using a boost circuit.
I figure that if products like the ARC AAA can run 1 LED off 1 AAA cell with decent runtime then what I want to do with 4 LED's and a cell with 14x the capacity should be OK.
Is my reasoning sound or have I forgotten something?
Streak
Re: 4 x 5mm LED\'s off one D cell?
Why stop at 4? /ubbthreads/images/graemlins/grin.gif
a d is approimately 3-4 amp hours...
might i suggest a linverter or similar?
neg
an alkaline d is 18ah iirc.
[ QUOTE ]
neg
[/ QUOTE ]
I thought aa had about 2500 mAH
and I think ( not sure )
that the internal cell resistance on a d battery is higher
and the 15 to 18 am hour spec for a d cell is based on a really low current drain spec.
[ QUOTE ]
[/ QUOTE ]
It is, but it still has significantly more than 3-4 amp hours even under high drain. The 4 LEDs the original poster is talking about is an extremely low drain, so it will run for quite some time.
How do you do the quote box ?
very true It will run for quite a while
MD.
[ QUOTE ]
Streak
[/ QUOTE ]
The relative capacity between the AAA and D cells depends a bit on current drain but your 14X sounds reasonable. For your application, the convertor board out of a Dorcy 1AAA LED light would be excellent. It would drive the 4 LEDs in parallel at around 20mA each.
Ummm your leaving out one thing. The AAA runs off of one cell, with one LED, but it has a boost circuit. The D cell has way more capacity, but it has the same voltage as the AAA.
I would higly recommend a boost for a single cell with 5mms.
Alkaline D cells should have about 18 amp hours. I have seen D cell rechargeables as high as 11 amp hours.
