FRITZHID
Hi ya LED guys, couple of quick questions for ya....
I'm working on taking an old incan Colman lantern (4sD, maglite bulb) and converting it over to led using 20 5050s & running them off 2s2p Ds in the stock holder.
I'm wiring the leds as a 3way setup, (1 chip in each for low, 2 for med, and all 3 for high). Max tested the batteries at 3.64v unloaded.
Q1, can I run this direct drive or must I use resistors with this setup?
Q2, IF I must use resistors, anyone have a nifty bypass for using one resistor for each chip? (60 resistors total is a tad much)
Q3, has anyone tried this yet? results?
Thanks all!
Thanks all!
