Sold/Expired M*gCharger extender tube (S O L D)
fivemega
California
I am selling my M*g Charger upgrade kit, including 72mm extension tube and 3 pcs battery adapter. M*g flashlight and batteries <font color="red">NOT</font> included.
I have machined this tube from D size black M*g barrel. It is factory black anodized and will match M*g Charger color.
Simply attach body extension to your M*g charger, insert battery adapters and 5 "C" size NiMH batteries to increase battery capacity from 2200 mAh to 4500 mAh. You can use original charger to recharge 5xC kit for about 30 hours or use your fast charger. Replacing original bulb is not necessary, unless you want to get higher performance using WA1160, WA1111 or....
You can also use extension tube without battery adapter to use 7x1/2D to overdrive WA1274 for 600+ Lumens output or use 4 full size D and WA01183 (400+ Lumens) for long run time. (Over 2 hours).
More info: http://www.candlepowerforums.com/ubbthreads/showflat.php?Cat=&Board=UBB14&Number=530196&Forum=
$35 shipped to USA
International buyers please add $5.00
First " <font color="brown">I will take it</font> " will get it.
Paypal: [email protected]
Any comment welcome, any suggestion appreciated.
jdriller
New York
Re: M*gCharger extender tube
Fivemega does fine work! Fit and finish are excellent. Makes the M@gcharger very versatile. /ubbthreads/images/graemlins/goodjob.gif
turbodog
central time
Also, what's the possibility of you making me one that I could use to put 5 full size D cells in?
fivemega
California
It is possible. But if you want smooth tube (not knurled), then I need to sacrifice 5D or 6D M*g.
2D has 52mm and 3D has 88mm smooth end. You need 120mm extension.
