Katherine Alicia
I`v got a 5D maglite and at some point years ago a battery must have leaked inside, it`s all cleaned up now as far as I can tell, but it still doesn`t work.
the batts and bulb are fine, the switch sometimes clicks and sometimes sticks.
I`v removed the rubber switch cover, loosened the alan key screw and can move the switch assembly a little, it`ll go side to side, and it will move up (towards the bulb end), but it will Not move downwards towards the end cap at all?
it`s a pre 92 so it has the old switch assembly in there. I could probably take it out from the bulb end (it seems to want to move that direction), but there`s a plastic disc with 4 indents in there that wont move (like the locking disc on an angle grinder), do I have to insert pins into those and try and rotate that disc to unscrew it or something? because it will NOT move in the other direction and slide out the end cap side no matter what I try. it`s been sprayed in Teflon based lube and it still wont shift (though the switch is freer now! LOL).
I`v seen a replacement switch module for it, I just need to get this old one out first and I don`t want to have to melt it out.
any ideas?
any ideas?
