Some form of regulation is usually better, but with such a large battery, it would run quite long with a resistor before the voltage dropped much. If you put some form of quick change or switch selected resistors, you could start at say 5 ohms, switch to 2.5 when it stats to dim, and then zero ohms when it runs down again.
I've done this with my AAA DB mod and you can get five hours out of a set of batteries by lowering the resistance as the voltage falls. Kind of a 'human powered' voltage regulator.
With that big square 6V (8 D cells inside) your probaly talking 100+ hours of bright lighting. Of course, some current regulator might get even better milage............
