Hello NOS,
I bought this one-of-a-kind 4 cell emoli mod from Mac. It is a 458 mod and is a great performer. When I got it, I ordered an extra emoli cell because I was going to do a 5 cell emoli mod with a 6D Mag. (That is a 3D in the pic for size comparison.) Mac took out the stock switch and used a 10A tailswitch mod instead. (I believe if you send Mac a 6D tube, he would cut it down for a tailswitch mod like this, but you would have to check with him on that.) you can read more here about this light:
http://candlepowerforums.com/vb/showthread.php?t=192151
Fivemega makes these extension tubes for the Magcharger and they work great with regular D Mags as well. Not only that, but the long one is 78mm so it was perfect to extend my 4 emoli to a 5 emoli. You can order here:
http://candlepowerforums.com/vb/showthread.php?t=98251
Mac makes those little rings to center the batteries in the D lights which I really like. You could do the same with PVC pipe and a little work. These are 26700 size batteries and they have about 20% more mA's (Mac says 2800 mA for the 26700 in his sales thread) than the emoli 18650 version. The A123 batteries have significantly less mA's than the emoli's also.
These batteries have stainless steel cases and will handle very high amps. One click and this baby lights up your world.
You can buy the batteries here on CPF here:
http://candlepowerforums.com/vb/showthread.php?t=178188
There is a LOTmore battery info here.
http://candlepowerforums.com/vb/showthread.php?t=185950
Both the 4 cell and 5 cell emoli mods with the 458 are INSANELY bright. When I shine it on the wall with the lights on inside and in broad daylight, looking at the hotspot on the wall makes my eyes hurt a little until they get adjusted.
You may have to upgrade the switch on the 6D (maybe too many amps for stock switch
), but I figured 5 emolis would fit just about right in the 6D (before I found Fivemega's extensions that is.)
If you compare the lumens estimated from actual lux readings in LuxLuthor's test page, the 4 cell emoli (14.8V) running a 64623 at 5000L is very close to the 5 cell emoli (18.5V) running a 64458 at 5904L. It is a little easier to instaflash a 64623 on a freshly charged set of batteries though. So if you want to consider a little shorter light than a 6D, that is an option.
You may have known all or some of this already, if so just disregard.
Good luck with your mod. You will like the 26700 emolis in the 458 mod.
